April 08, 2026, 06,15:33 PM *
Author Topic: I have a question.  (Read 23681 times)
« Reply #30 on: March 03, 2011, 08,58:21 PM »
You can still do that, have a look at the website (www.clake.com.au).  It is all to do with the settings of the cams.  Basically the first part when you pull in the lever is to enough to give you clutch slip and then rear brake starts to comes on more prgressively as you keep pulling in the lever.  It doesnt take long to get a feel for where the transition is between the two.  If you want more or less overlap you can get different cams.  It is quite expensive but is tranferable from bike to bike.  It is amazing to come into corners and be able to keep the rear brake just off the locking point.  You can also come into right hand corners put the foot out but still apply rear brake if needed.
« Reply #31 on: March 03, 2011, 09,11:25 PM »
Simon, the footpegs were put there for a reason. No trail rider should be using a foot as stability in corners. Ever seen a spiral fracture, not fun.
« Reply #32 on: March 03, 2011, 10,42:29 PM »
Learn clutch, brake and throttle control. Save your money and spend it on suspension.
Phil Randall
« Reply #33 on: March 04, 2011, 08,16:34 AM »
Stewart,  try < www.clake.com.au >  Good aussie invention !!.
Phil R.
Regards,
Phil Randall
« Reply #34 on: March 04, 2011, 02,50:07 PM »
I did check out the Clake. An amazing piece of engineering. And it is Aussie made  Grin
GoogleTagged: d2k clutch www 90237346 tight braking there engine dmq
aww 75775273 google 45175338 70810081 cluth recluse wr450 with clake
Google visited last this page January 10, 2026, 12,22:34 AM
