April 08, 2026, 11,19:50 AM *
Author Topic: YZ 250 OR RM250 (2T) as a trail bike/ enduro  (Read 19959 times)
Glennboy
Albury Wodonga
« on: June 01, 2012, 09,50:40 PM »
As an alternative to euro 2t bikes what would a Yz250 or RM250 2 stroke motocross bike be like as a trail bike? (enduro).
I Would be willing to add a headlight, taillight for Rec rego and change the  gearing/ exhaust etc for more bottom end but what do you think.
Suzuki DRZ 400e, Husqvarna WR250 gone, now TE449
« Reply #1 on: June 01, 2012, 10,10:07 PM »
Bad idea.
« Reply #2 on: June 01, 2012, 10,13:27 PM »
Bad idea.
why?
« Reply #3 on: June 01, 2012, 11,05:47 PM »
Gearbox will still be shorter and close ratio, fuel tank is smaller and suspension tuned for motocross so harsher than a trail setup. If you ride hard all the time then o.k. but will be a compromise over an enduro 2T bike. Even changing the final gearing and pipe will still have less bottom end so may struggle in snotty stuff.
That said, lots like a motocrosser in the bush so why not. It would have to be cheaper than a euro 2T to make it worthwhile.
« Reply #4 on: June 02, 2012, 06,42:09 AM »
Mat has brought up some good points, but (at least for the YZ) they can all be addressed if you choose to do so.
I have an enduro-ised 2T YZ250 (2008) - for me, the bike is great fun to ride in the bush.
To address the shorter ratio gearbox, I fitted a complete set of WR400/426 gears (slight case mods required) and dropped the final drive ratio down to 13/52.
IMS, Clarke and Acerbis all make long range tanks, and you can fit a fuel tap with a reserve to give some warning if you are running low on fuel. I have a 13ltr IMS tank.
The power delivery is smoothed out by adding a heavier flywheel - in my case a 9oz GYTR flywheel. Some people prefer heavier ones, but I still like to be able to feel the snap that the engine produces - although it does make it a bit of a handful in the wet clay at times.
The standard exhaust pipe does a pretty good job of allowing the bike to 'tractor' when needed - I fitted an aftermarket silencer to drop the noise level down.
The rear suspension was able to be adjusted to cope well in standard form, but I modified the shim stacks in the front suspension to soften the low speed initial hit, as it was harsh in standard form.
I initially bough an aftermarket 'lighting' stator for running the lights, but this failed on the first trip out (luckily just a few kms from home), so I replaced it with an LED kit setup from Small Coil Rewinds - not the brightest of lights, but legal for rec rego.
A set of barkbusters, bash plate, pipe guard, and it was good to go!
It is still a motorcross bike, but just a 'softened' version.
Final cost worked out cheaper than getting a euro 2T, but not by much. I also miss out on the electric start, but that hasn't really been an issue so far.
I enjoy customising things, so the conversion work on the YZ was a fun project.
« Last Edit: June 02, 2012, 06,52:11 AM by flipper » Logged
« Reply #5 on: June 02, 2012, 09,01:45 AM »
Thanks Flipper, I'm sure Glenboy will appreciate your input.
GoogleTagged: 51495398 riding ims all powered aww amtra 57967247 fora
54176721 56343320 ewu yz25 bike 450 nsw for 86475890
Google visited last this page February 07, 2026, 03,59:13 AM
