October 04, 2026, 02,03:49 PM *
Author Topic: Tyre and Tube change and removal  (Read 19008 times)
« on: January 23, 2013, 12,36:33 PM »
After going on a few rides lately where there has been a few flat tyres, and people not really having the skills to fix the problem, me included, i decided that it was time to improve my tyre and tube changing and fixing skills.
The last thing i want is to stand around while someone else fixes my bike.
I hit the net and did some shopping at Torpedo7 on wednesday last week, and bought some things to make tyre changes in the shed a little easier.
I got this tyre changing stand on sale for $40
http://www.torpedo7.com.au/products/T7TOTNNTC/title/torpedo7-portable-tyre-changer-with-bead-breaker
These tyre spoons for $10
http://www.torpedo7.com.au/products/T7TO4N0TL/title/torpedo7-260mm-tyre-lever-set---2pc
And this long lever for $7
http://www.torpedo7.com.au/products/T7TO4NNTL/title/torpedo7-tyre-lever---350mm-twin-tip
They and some other things turned up yesterday morning, and after assembling the stand i was keen to have a go at changing a tyre.
Looking at the front tyre on my 310 it had plenty of life left in it, but i've never really liked Bridgestone front tyres as i feel they have no mid corner grip, so it was decided to replace it with a Michellin S12 my favourite front tyre, and all i would do to the rear Bridgestone 404 was turn it around.
I went down to AMX in Bayswater and purchased a S12 front for $78 and noticed that S12 rears were $98 which i thought were pretty good prices.
When i got home and before getting stuck in i searched youtube for a vid on changing tyres and found this, i watched a few and this was by far the best.
http://www.youtube.com/watch?v=uzGsrsUGMw4
After watching that a couple of times it was time to hit the shed and get my hands dirty.
Getting the tube out was easy and getting the tyre off the rim took a little more effort than the vid but it came off without to much swearing.
The inside of the rim was filthy so i cleaned it up as best i could, the rim tape was knackered so that was replaced with black electrical tape and the rim lock was cleaned up.
Time to fit the new tyre, while i was removing the old tyre the new one was in the sun to warm up and it went on the rim fairly easily, in with the tube, the valve went in easily using the method in the video, now to put the tyre onto the rim. With plenty of lubrication and small bites, a bit of muscle and plenty of sweat the new tyre was installed!!
Now for the moment of truth! had i pinched the tube Huh Huh i pumped the tube up to 60 psi to seat the bead so i'm fairly certain the tube wasn't pinched!!! Grin
I did up the rim lock put the wheel back in the bike and sat back with a satisfied grin on my face looking at the back tyre Sad
Looking at the rear tyre i thought it had a couple more rides in the direction it was going so no need to rotate it, but then i thought just rotate it you need the practice.
So it was back to youtube to watch the rear tyre changing vid.
http://www.youtube.com/watch?v=DqiSV4WZb-c
So it was off with the back wheel and start the process of removing the tyre.
Breaking the bead was easy and so was removing the tube, and what surprised me was that i actually got the rear tyre off easier than the front!!
Looking at the inside of the tyre the strings on one side of the casing had come out of the mould, so after a lot of indecisiveness i decided to ditch the rear and buy a new one. By that time AMX was nearly closed so i would have to wait till the morning to get a new rear tyre. So i cleaned up the rim and replaced the rim tape with electrical tape and cleaned up the rim lock.
Went down to AMX this morning and bought an S12 rear then come home to install it.
i got the tyre on the rim easy enough, didn't worry about putting it in the sun for a while, i was fiddling about trying to get the valve through the hole so i gave up and used the valve puller instead, easy.
With plenty of WD40 on the tyre and with small bites the rear tyre was on!! Grin
again waiting for the moment of truth, the tyre was inflated to 60 psi and the bead seated on the rim!!!  Grin Grin Grin Happy Days, i must have improved my technique as i got the rear on easier than the front, and typing all this has taken me longer than putting the tyre on.
In summary it really isn't that hard.
*Take your time and have the right tools
*Lubrication is essential
*small bites and don't take levers past centre
*Patience, if your having trouble go back to the vid ( if you're at home )
*Have a go what's the worst that can happen
*Tyre installation is much easier without the rim tape holding the rim lock against the rim.
No more having the shop fit the tyres for me, the more i do it the easier it will become and i think it's a skill all riders should have.
« Last Edit: January 23, 2013, 12,40:54 PM by nathanstott » Logged
Btoan
« Reply #1 on: January 23, 2013, 12,57:28 PM »
I purchased all the same stuff from Torpedo7 but I didn't use youtube to show me how to do the change, Gary Clarke came buy and showed me how to do it all.....only problem I will have to get Gazza back next time because I have forgotten how to do it.... Wink Wink
« Reply #2 on: January 23, 2013, 01,06:21 PM »
You should fit every tyre you buy yourself untill you do it with ease then you can get the shop to fit it.
But $10 to get it fitted is very tempting..
« Reply #3 on: January 23, 2013, 01,12:01 PM »
Maybe Gaz should make a vid and stick (no pun intended ) it in this thread!! Grin
« Reply #4 on: January 23, 2013, 01,52:06 PM »
Great article, Nath.
Still, I wanna see you carry that tyre changing machine on a ride!
I get most of my tyres done at the shop.  I know I can change them myself, but it's generally not a pretty sight!  Having said that, I've only ever had one flat on the trail, and that was with a very old tyre I had on a bike I was borrowing.  Maybe I don't ride hard enough, maybe I'm just carefull, but touch wood, I hope it stays that way.
Thanks for taking the time to put that all together.
« Reply #5 on: January 23, 2013, 02,34:16 PM »
I would really like to come and watch the next time you do it , a part of me thinks it would be entertaining.
A wise guy told me if you are changing a tyre and its really hard to do , pull the tyre off an start again becasue you are doing something wrong .... Its amazing
how quick you can do it with practice.
All jokes aside great work Nathan excellent post.
« Reply #6 on: January 24, 2013, 02,54:00 PM »
Awsome read.
I remember a lot of cursing and sweeting the first few tubes I changed and that was just after my fist AMTRA meeting(you need ultra heavy duty tubes they all say) Wink.
I went a lot of years with out a flat but then I got two in a row on one of Wills rides  Sad
« Reply #7 on: January 25, 2013, 08,02:52 AM »
I'd rather spend the $10 on beer to drink wilst changing the tyre. Plus I normaly buy 3-4 tyres at a time and have them in the shed ready to go when needed. I'll also refit half worn out tyres to totaly wear out over the summer up here.
Btoan
« Reply #8 on: January 25, 2013, 10,37:26 AM »
I was a member off old bulls and we made a video of me changing a tyre....it is on there website.
« Reply #9 on: January 25, 2013, 11,05:58 AM »
I've only ever had one flat also and i always run uhd tubes, not much you can do when you pick up a nail!!
You don't know it yet but your carrying the tyre changing stand for me!!  Grin Grin
Hope your not busy Saturday!
« Reply #10 on: January 31, 2013, 06,01:26 PM »
Just put a new set of boots on the 449, took an hour and a half to remove wheels from bike swap tyres and reinstall wheels on bike, it's getting easier, slightly, and i don't think i will break any records, but definately comfortable changing my own tyres now.
I might actually be usefull as a sweep at the HCR
« Reply #11 on: January 31, 2013, 06,28:35 PM »
Usefull sweep, noted!!!
« Reply #12 on: January 31, 2013, 06,30:44 PM »
"Good Boy"
Now did you look at the wheel bearings and clean out the Seals ?
Hope you cleaned the Axle and re-grease it before you put back in !!
« Reply #13 on: January 31, 2013, 06,55:40 PM »
"Good Boy"
It had new wheel bearings front and rear 1 ride ago so no i didn't clean out the seals.
I always clean and re-grease the axles every time they come out of the bike!!
« Reply #14 on: January 31, 2013, 06,58:39 PM »
You should have been at the meeting last night.  You would have gotten a heap of special valve removing valve-caps, to put on all those tyres you're gonna change!
GoogleTagged: what torpedo7 ultra com 46865395 agc with changer 53899372 amtra
83339334 58187178 56146854 dgc 44770516 skills tubes tyres 57155469 80185997
Google visited last this page February 02, 2026, 06,55:17 AM
