October 01, 2026, 06,20:30 PM *
Author Topic: Sub frame repair  (Read 6928 times)
pez
« on: May 22, 2009, 09,46:54 PM »
I need help locating a person that will straighten my sub frame.
I have a KTM 380 that has hit the deck a few times and after fitting a new back tyre last week I noticed the sub frame must be bent at it looks like the tyre has been rubbing on the left side of the airbox, side plate area.
There are no cracks in the sub frame and all the mounts are good. Looking from the rear of the bike its bent to the right.
Or can I do this myself somehow? I don’t really want to get a steel bar and try as I feel this may break the welds.
Any help would be apreatiated. Grin
« Reply #1 on: May 23, 2009, 10,58:06 AM »
Don't throw it down as much!!
It helps to keep the frame straight.
« Reply #2 on: May 23, 2009, 07,24:28 PM »
Do it yourself, it cant be to bent if you've only noticed it while doing a tyre.
Use a length of wood and push/pull it into line.
The welds will take it. Wink
« Reply #3 on: May 23, 2009, 08,22:53 PM »
Next time, crash on the right. Tongue
pez
« Reply #4 on: May 25, 2009, 08,05:27 PM »
HAHA you try not to crash a 380
But honestly Yes Tim have thought about that but the frame has been welded once before so really dont want to stress it out again. Grin
Would heating the sub frame in an Oven at 230 deg and then a gentle bend back do it?
Thats how I straitended a bent radiator and thats worked for years now without a single leak.
« Reply #5 on: May 26, 2009, 09,02:39 AM »
230 deg is no where near hot enough for steel, cold bending would be a better option, just remove the guard and like Tim said and use brute force it wont hurt anything
GoogleTagged: subframe repairs google
Google visited last this page August 09, 2026, 12,21:56 PM
