April 08, 2026, 02,57:42 AM *
Author Topic: Fork tube straightening  (Read 9371 times)
« on: July 06, 2013, 04,31:10 PM »
I picked up a drum brake front end for an '83 TT600 a little while back.
Intitally it looked to be okay, but upon disassembly, I've discovered that the chrome fork tubes have a slight bow in them.
If you roll the chrome tubes on a flat surface, there is about 3mm of bend in the overall length - not a huge amount, but it is causing binding of the forks when they are compressed without the springs in place.
Does anyone know of a place that can straighten these out?
And what sort of cost is associated with it?
Thanks
Peter
« Reply #1 on: July 06, 2013, 05,07:00 PM »
Thanks
Peter
Garage press and a block of wood should do the trick
« Reply #2 on: July 06, 2013, 06,19:37 PM »
Knowing my luck, I'd probably squash the tube flat!
I was under the impression that it needed to be done with v-blocks and a dial gauge to make sure it was straight.
« Reply #3 on: July 07, 2013, 08,11:30 AM »
John is right it will straighten it but be careful. "V" blocks and dial indicator is the ideal way of doing it but not everyone has them and probably a over kill.
Phil E
« Reply #4 on: July 07, 2013, 09,11:52 AM »
I would take it to a suspension specialist. I use SPMX in Seaford.
Current ride:Husky TXE310
« Reply #5 on: July 07, 2013, 09,17:45 AM »
Or speak to Chad at Chad's Offroad Setups.  He's a good AMTRA friend and has been hassled by some of my requests over the years!
« Reply #6 on: July 07, 2013, 11,46:06 AM »
Each to there own
As you said it is only 3mm deviation
cut your self 3 vee blocks out of wood if you have a hole saw the same size as the fork tube even better drill a hole
in the wood and  cut it half set it up an the bench mark your high spot and give it a gentle press if it doesn't work
take it to a shop
nothing venture nothing gained
PS only use wood near fork tube
GoogleTagged: dgc 70138588 53217764 com 110151844 amtra 59930103 88198703 dgi
b2i google 85970519 dgy cge
Google visited last this page February 23, 2026, 11,47:42 AM
