April 08, 2026, 10,47:04 AM *
Author Topic: Should You Go Tubeless? - Standard Vs. Tubeless Tires  (Read 5010 times)
« on: September 30, 2009, 07,56:16 AM »
Is anyone running a tubeless kit to convert your standard tube/tire system into a tubeless tire system?
If so whats the feedback less flats or what?
Also if I got a flat with a tubeless setup could I pop a tube in or is the tyre now rim locked on?
« Reply #1 on: September 30, 2009, 10,06:29 AM »
They look interesting, and have thought about trying one on the front.
If you run a sealant inside then the only way you should be able to get a flat is if the tyre gets a large cut, in which case you may be just as stuffed as with a tube set-up.
There are tyre plugs for small holes in the tyre.
Putting a tube in after a flat is probably not going to work unless you ditch the tubliss and they don't seem to be a compact thing to carry out with you on the bike.
GoogleTagged: tubliss com google amtra
Google visited last this page March 19, 2026, 04,18:20 AM
