April 08, 2026, 09,24:22 PM *
Author Topic: 250 EXC gearing  (Read 16792 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: 45175338 yms 40-49 down exc 64125504 gearing 2010 59568121 46471029
zwu 2012 the 50310824 dgi 74649129 59026428 67720277 dgc agc
