April 08, 2026, 11,04:15 PM *
Author Topic: 250 EXC gearing  (Read 16798 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: smf com speed stock d2k 74649129 2011 the standard 250
40-49 gearing foe 2012 for bge 67720277 52434380 dgc wr250f
