April 08, 2026, 11,07:36 PM *
Author Topic: 250 EXC gearing  (Read 16804 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: c2e 2010 standard 40-49 foe amtra stock d2k 68911936 2012
2011 60799247 59568121 gearing wr250f 59026428 2stroke zwu exc size
