April 08, 2026, 11,05:57 PM *
Author Topic: 250 EXC gearing  (Read 16802 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: com yms c2e smf what 2010 exc 68911936 google speed
the 52434380 74649129 zwu 67720277 50310824 wr250f 60799247 exc250 powered
