April 08, 2026, 11,05:52 PM *
Author Topic: 250 EXC gearing  (Read 16801 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: 250 dgi zwu google for stock 59026428 60799247 52434380 2010
59568121 2011 exc250 gearing 68911936 50768961 2000 2012 standard c2e
