April 08, 2026, 11,04:20 PM *
Author Topic: 250 EXC gearing  (Read 16800 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: exc250 2012 bge down 52434380 gearing 2010 for 2000 40-49
size standard 59568121 45175338 the exc 250f 64125504 68911936
