April 08, 2026, 11,04:18 PM *
Author Topic: 250 EXC gearing  (Read 16799 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: agc the 2011 zwu com standard dgc 67720277 speed exc250
bge 59026428 2000 ktm amtra c2e d2k what dgi 2stroke
