April 08, 2026, 11,03:15 PM *
Author Topic: 250 EXC gearing  (Read 16797 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: 52434380 amtra stock 46471029 250f google 2011 d2k zwu 50768961
down exc 59026428 74649129 250 45175338 67720277 wr250f 59568121 foe
