April 09, 2026, 02,26:52 AM *
Author Topic: 250 EXC gearing  (Read 16813 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: wr250f gearing size 2stroke exc250 2010 dgi dgc 59568121 yms
powered amtra 50310824 top 40-49 60799247 smf for 52434380
