April 08, 2026, 11,07:36 PM *
Author Topic: 250 EXC gearing  (Read 16804 times)
RyhnoBurger
Check this out:
Pete
I run 13/52 on my WR 250.
14 - 48 works for 250EXC
Milktoast
Come on Mr Toast
RyhnoBurger
GoogleTagged: for stock what c2e best 59026428 45175338 smf foe 2010
ktm powered 68911936 59568121 zwu 2000 d2k 46471029 50768961 exc
